Not necessary, slot the bracket holes and leave them be. I know of a couple RV's that are flying this way. The aileron bracketry was off on my F1 and since those were predrilled to the ailerons I had to slot the holes with my milling machine. As long as the bolts are tight nothing will go anywhere and I can't see any way that the aileron could be loaded in such a way to cause movement down the length of the slots.
But if you want to sleep better you can always drill another hole for another nut/bolt to lock it in place.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
