Only speculating but I suspect that the issue is with switching the alternator on when the engine is running. How the alternator output voltage behaves in the next few milliseconds depends on the particular voltage regulator, alternator and wiring. Some installations may see a voltage surge that would again trip the over voltage detect thus re-opening the breaker.
Tieing master and alternator switches with a DPDT switch essentially just ensures the alternator is on during start.
I see this as a good configuration - avionics are protected irrespective of the regulator and alternator setup.
This is the configuration in my RV-6. I have had a loose connection to the voltage regulator - the OV circuit tripped each time I tried to close the breaker. Returned for a safe landing with plenty of battery reserve.
In practice with the split master I doubt it will be a problem. If it does trip when you turn on the alternator after start you know it has protected your avionics. I liked that the install was so simple - two leads to two terminals on the master(/battery) switch.
The LR-3c is a more expensive option, not sure if it is better.
Doug Gray
RV-6 completed, flying since July 2010
Reason: Spelling...
