Old 01-29-2013, 07:10 AM
flyenforfun's Avatar
flyenforfun flyenforfun is offline
Default Cleaning oil off of new paint
Looking for some suggestions from everyone. We picked up our -8 from the paint shop about a month ago. I know the paint is still new and probably soft because it has been in the 30s all month, but a hammerhead the other day resulted in a ton of oil all the way down the belly of our airplane.
Wanted to know what I can use to clean all of this off the paint. Something safe for paint and clear coat and gentle enough to not harm a new paint job. Thanks for the suggestions everyone.
-Matt
Matt Giordano Sr. and Jr.
RV-8 - N861MM
Wilmington, DE
Old 01-29-2013, 07:28 AM
Walt's Avatar
Walt Walt is offline
Mineral spirits
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 01-29-2013, 07:32 AM
Taildrgr's Avatar
Taildrgr Taildrgr is offline
How about dish soap and water.
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
Old 01-29-2013, 07:41 AM
Brantel's Avatar
Brantel Brantel is offline
Goop!
Wipe on, let sit, wipe off with a little sprits of water.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-29-2013, 11:39 AM
Originally Posted by Brantel View Post
Goop!
All is safe on new paint? Even mineral spirits?
RV-8 - N861MM
Wilmington, DE
Old 01-29-2013, 11:43 AM
Call your painter.
Old 01-29-2013, 12:05 PM
rleffler's Avatar
rleffler rleffler is offline
Like Bob mentioned, call your painter. It depends on what paint they used.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-29-2013, 03:13 PM
bird's Avatar
bird bird is offline
plain dawn detergent mixed with water will not hurt your new paint.
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 01-29-2013, 03:53 PM
g zero g zero is offline
Default Cleaner
Sparton SD 20 ,an aerosol spray , get it at the local janitorial supply . Cleans oil , grease etc. with no residue .
Tom
Old 01-29-2013, 07:31 PM
turbo's Avatar
turbo turbo is offline
come on down to florida and cure that paint. its in the upper 70's tonight. then we can clean up that rv before we go to sebring wednesday morning.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
