Old 01-28-2013, 11:32 AM
larrynew's Avatar
larrynew larrynew is offline
Default Properly Wiring LED Dimmer
I've searched my copy of the Aeroelectric Connection, AC43, B and C, Steinair and this site and can't find the proper "aircraft" way to wire my LED Dimmer. Are there tiny tabs to fit the 4 tiny slots? Or do I tin the wires and insert them and tighten the screws? Just securing the wires with the screws doesn't seem very secure compared to ring terminals or faston tabs.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 01-28-2013, 11:50 AM
My RV-8 has a similar controller. The builder did not tin the wires prior to inserting them into the slots and "clamping" them down with the set screws. It's worked fine and I re-installed the same unit the same way during my panel upgrade. YMMV
Old 01-28-2013, 01:12 PM
ILikePike ILikePike is offline
I have used those green screw terminal blocks on airport lighting controls. tinning the wire ends may be wise but shouldn't be nessessary.
Not trying to steal your thread but, I have been working on electrical system design for my 8. I have not made all lighting choices yet, but I am planing 4 dimmers and all LEDs 1)instrument flood, 2)instruments, 3)pilot cabin, and 4)copilot cabin. Control 4 will preferably be in reach of pilot and GIB. The controller shown above is cheap and can handle 6 amps. Good choice or should I be considering some controllers like those found at ACS?
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2019
Old 01-28-2013, 01:22 PM
BillFear BillFear is offline
Default I used the same unit
We use this style connector on industrial products with good success. I just used it on the twisted copper stripped wires, will tin them when I add my cargo area light at this years conditional. I fused this circuit right at the battery in case there were any shorts in the wiring or the LED strips.
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
Old 01-28-2013, 02:24 PM
JonJay's Avatar
JonJay JonJay is offline
I would hook up your dimmer and LED's on a test power supply along with an intercom or radio and see if you get any interference.
"PWM" stands for Pulse Width Modulation. They vary the power by adjusting the frequency of the pulses through rapid switching of the solid state device. From the looks of the simple board, there is nothing else going on there in regard to filtering so I would suspect this controller to be quite noisy.
Not an issue in your kitchen. Might be in your airplane.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-28-2013, 02:52 PM
MarkW's Avatar
MarkW MarkW is offline
Tinning a stranded wire would be similar to soldering a crimp on terminal. I believe I have read that this is not recommended. I think it adds rigidity to the connection which can cause the wire to break rather than flex. I would simply twist the stranded wire and tighten the screw.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 01-28-2013, 03:02 PM
JonJay's Avatar
You are correct, but the rigidity of the wire occurs if you allow the solder or flux to wick up into the insulation. A properly stripped and tinned wire should not be rigid or brittle.
To your point, a terminal connector captures the insulation making it very difficult to impossible to solder without it wicking up the insulation. That is why it is not recommended on terminal connections unless they are bare wire, like a ground strap etc...
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-28-2013, 03:05 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
I have two of these exact dimmers in my plane and while not flying, all the electrical and audio checks I've done have produced zero interference. As far as the wiring, I crimped a D-Sub male pin onto each wire and then inserted that into the connector and screwed tight. The wire can't be deformed this way and nothing gets brittle. For power connections I add a little shrink tube to the d-sub to protect them from ground contact.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 01-28-2013, 03:13 PM
JonJay's Avatar
Good to know. I suspect the "noise" is still there, but if it isn't affecting anything.....
Probably a credit to the quality of the intercom and radios we are using today or it is simply modulating outside of any frequency that causes any problem.
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-28-2013, 03:14 PM
bird's Avatar
bird bird is offline
We use this type connector at work a lot, stranded wire can be inserted and it will remain a good connection, other choice would be , as mentioned above, crimp a pin on and secure it in the connection. By the way, where can I buy that dimmer, I need one, what is the part #? Thanks
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
