Old 01-28-2013, 07:53 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Default Oil Cooler - Test Pressure?
Tried a search but no direct answer immediately apparent.
I have the stock Vans Oil cooler, and it's done about ~500hrs and is ~6years old, but not been used for ~1 year. Have the opportunity to pressure test before back into service, so does anybody have any advice on a suitable pressure to test it to?
I see Niagra "pressure test" to 400psi and "leak test" to 100psi - apart from the nomenclature, not exactly sure of the difference? I'd use that as a start unless somebody has a good alternative
Thanks in anticipation...
Andy & Ellie Hill
RV-8 G-HILZ
RV-3B G-HILI very slow build
RV8tors
Old 01-28-2013, 09:50 AM
mannanj's Avatar
mannanj mannanj is offline
Default Press.
Andy:
if you're using compressed air or gasses at 400psi, make sure that you do like the SCUBA guys do and fill the cooler and associated hoses with either oil or water first.
If it blows you'd spread liquid around instead of shrapnel!
I'm sure that you knew that though.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 01-28-2013, 10:21 AM
Andy Hill's Avatar
Thanks for that - I do now, and understand the compressibility issues between gasses and liquid.
However, by
I meant I will be ~100 miles from the Oil Cooler when the test is done (by pro's), so hopefully that will be far enough
Andy & Ellie Hill
RV-8 G-HILZ
RV8tors
