My engineer is installing a Digiflight II in my RV6 and has come up against a small problem. When installed as per the instructions, the throw on the bottom of the control stick is 3 inches against a maximum throw of 2.5 inches on the servo. The result is the servo goes over-centre. Has anyone come up against this issue and how did you deal with it? All help and advice very much appreciated.
