Replacing Stratoflex Hoses
Hello,
Due to the limited service life of 8 years, the oil hoses of my christen inverted oil system need to be exchanged. The Startoflex 156-10 hoses use Stratoflex 676-10 Fittings. The Stratoflex service manual allows the reuse of the fittings if inspected thoroughly. This way only the hoses need to be replaced.
However, there are O-Rings inside that I would have replaced as well.
What have you done here?
Are the O-Rings available seperately?
Thank you for your answer
Thomas
