Dimmer
Dean,
Just checking to obvious first. Do you have the VM1000 connected to a dimmer? If so, make sure it is bright. The VM display will flash sometimes on startup, then default to the dimmer setting. (i.e. dimmer on low, light goes off / dimmer on high the light stays on).
Email Reggie (Glas467) on here. He is the VM guru and will be glad to help out. He has helped me numerous times.
Dan
Dan Thompson
RV-6A - N426JM - 180hp / C.S. / dual PMags
NC26 - Long Island Airpark, NC
