Old 07-27-2006, 05:02 AM
TShort TShort is offline
Default Ethanol power
I read this thread and watched most of the video:
http://www.vansairforce.com/communit...hlight=ethanol
Interesting stuff.
Has anyone seen the fleet of RV-3s and the -8 that are at OSH and fly on ethanol? They are running injected lycomings and powered by ethanol. Just NE of Aeroshell square. Only got to talk to them briefly, but it sounds like things are going well.
It is reassuring to know that even if 100LL goes away some of our current engines will run on ethanol. Just think ... if the hangar fridge is out of beer, you could just sump a little "fuel" from the plane after the flight instead!
Thomas
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 07-27-2006, 08:06 AM
prkaye prkaye is offline
Very cool... do these engines have to be modified in any way to run on ethanol?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 07-27-2006, 08:31 AM
I only talked to them briefly as they were pushing the planes in after landing on Monday ... he said it is only a minor mod to the fuel injector system (servo) and that's it.
They were nice looking RV's, too - four RV-3's (two with wing tanks and two with bulkhead tanks) and an RV-8.
Hopefully someone else will get a chance to get more info. I'm surprised they have not been publicizing them more.
Thomas
Thomas Short
Old 07-27-2006, 08:34 AM
where do they get their ethanol?
After the modification, do you know if the engines can still use 100LL, or will they then run ethanol only?
Phil
RV9A (SB)
Ottawa, Canada
Old 07-27-2006, 08:50 AM
Dunno the answer to either.
I have a buddy who is still at OSH - I'll call him and ask him to stop by and ask some questions.
T.
Thomas Short
Old 07-27-2006, 09:04 AM
Low Pass's Avatar
Low Pass Low Pass is offline
The BIG problem to me is the loss of range/energy density issue. About 40% less BTU's/gallon. But then again, if I had ADM payrolling me and my plane, I might change my mind.
Bryan
Houston
Old 07-27-2006, 09:15 AM
I agree. I don't plan on using it in the near future.
But, if 100LL is gone, at least I know my engine will be usable.
T.
Thomas Short
Old 07-27-2006, 09:23 AM
Default engine choices
A consideration for me, and other builders who aren't at the engine stage, is looking down the road. When the time comes, I might want to make my engine choice carefully so that down the road I could convert to an alternative fuel as painlessly as possible. For example, maybe fuel injection is a better option in this regard? Other considerations? O-235 vs O-320 ??
Phil
RV9A (SB)
Ottawa, Canada
Old 07-27-2006, 09:35 AM
N941WR's Avatar
N941WR N941WR is offline
Phil,
The O-235 is a "high compression" engine and requires 100LL. Some of the O-320's are "low compression" and can run on 80 octane or higher. Meaning you can run regular unleaded (87 octane) or better.
I have heard that some of the new "high compression" engines can run on premium unleaded (93 octane) but you will need to check with your engine manufacture.
The carb vs. fuel injection might be an issue, I don't really know. Either way, FI can be fitted to any of the Lycomings.
FWIW, my O-290-D2 has a 7.5 to 1 compression ratio and can run 80 octane or better and, unlike other Lycomings, the timing is 18 degrees BTC.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-27-2006, 09:47 AM
Thanks for that information... I know very little about engines (haven't read that Bingeles book yet).
Some of them? How can you tell which ones? Can the RV-9A be fitted with any O-320?
Is that a high or low compression? Do you recommend this engine?
What does this mean?
Phil
RV9A (SB)
Ottawa, Canada
