I considered to plenum or not to plenum when starting the RV-10. I had some experience by helping a friend finish a -10 with a homebuilt plenum and also converting a -7a from stock to plenum that resulted in a 30 deg drop in CHT's at the same conditions and retained the same TAS.
The goal with the RV-10 was to spend as much time as necessary to produce maximum airspeed at cruise without overheating in the climb.
The louvers on the bottom of the -10 that most people are using looked less than optimal to me so I set out to eliminate them and still cool the engine.
The engine is a IO-540 C4B5 that was fitted with 9.1:1 CR pistons and new flow matched tapered barrel ECI Cyl's.
Here is some of the baffle and plenum pics.
here is a pic of the cowling to inlet intersection. The gap that you can see is sealed completely around the inlet with a rubber seal.
below the engine we tried to help smooth the air flow as it went out the exit.
I flew the first 25 hrs or so and determined that about the only way to keep the CHT below 400 F in the climb was to reduce climb power to 25" MAP and 2500 RPM and keep forward speed up around 120 KIAS.
I still was against putting louver on the bottom but felt I needed a slight increase in outlet area so I opened it up 3/4" like this.
After these modifications the cooling system will keep the cyls below 400 F when the OAT is 100 and plane is at gross weight taking off with a heat saturated engine with the Air Conditioner eating up 70 amps on the 24 volt alternator and climbing at 110 KIAS.
As far as efficient cooling flow goes. I have no way to quantify the amount of cooling drag reduction, if any, that was gained because this was not a modification but rather incorporated into the initial build. However, It will consistently fly 179-181 KTAS on 12.0-12.4 GPH so I have to believe we gained something for the effort.
I think there are gains to be had by utilizing a plenum but its not gonna work to just smack a lid on the stock baffles and expect good results......it takes work and work and lots of it!!!!!!!!!!!
