Question for anyone flying Vetterman's dual muffler/heat exhuast
I'm putting Vetterman's dual muffler/cabin heat source "tail" pipes in my RV-9. It provides two cabin heat sources, one on each exit pipe.
Have you folks used two separate fresh air inlets ? Or did you use a single source and split it with a "T" or "Y" fitting ?
If you used two separate inlet sources, where did you locate them ? Is it OK to put both of them in the baffle behind right rearmost cylinder ?
Any help appreciated ...
g
