Old 01-21-2013, 03:28 PM
JonJay's Avatar
JonJay JonJay is offline
Default Aluminum Brake Line Abrasion Protection
I used about a 3" section of spiral wrap around my 1/4" aluminum line where it exits the lower leg fairing. It has worked well to insure the bottom of the fairing does not abraid the line.
After 500 hours plus, there is some scoring of the material and I want to replace it. The only stuff I can find locally is 1/4" with a much thinner wall than the stuff I used, or 3/8" which is too big.
I only need a few inches of the stuff and I have no idea where I originally got it. Anybody know where I might find it in something less than 100' roll?
I am also open to other ideas but this works really well and is super easy to do.
If I can find some Polypropylene tubing I will just slice up what I need but would rather spend my time elsewhere.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-21-2013, 04:22 PM
Try McMaster.com.
Dave
Old 01-21-2013, 04:23 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Jon - I use some fuel hose I got at the auto parts store - rubber with internal braiding - and just slice it, put it where it needs to go, then use zip ties to hold it in place. It takes a LONG time for anything to abrade it away.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-21-2013, 05:05 PM
JonJay's Avatar
Paul
That'll work. Have some laying around. Thanks Paul.
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-21-2013, 05:25 PM
John---you can also try some clear hose from the neighborhood blue or orange home and aircraft improvement stores. I like the clear, because you can see the tubing, and check it during conditionals.
Tom
Ridgeland, SC
Old 01-21-2013, 05:53 PM
Rupester Rupester is offline
Default Spruce ...
Last time I looked, Spruce had the spiral wrap stuff by the foot, in at least two sizes. It was with the electrical stuff as wire wrap. I've purchased it from them three different times.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 01-22-2013, 09:48 AM
JonJay's Avatar
They do. The 1/4" stuff is not thick enough in my opinion to provide adequate long term protection. The 3/8" is too big. That seems to be what everyone carries, or you can order what you want from a huge shopping list online from Panduit suppliers and others. I will just break down and pay the freight, which is more than the stupid product, or follow one of the other suggestions.
For what it is worth I like the spiral wrap for several reasons;
My brake lines make a turn immediatley after exiting the bottom of the fairing and the spiral wrap conforms easily around it.
A 3" section of spiral wrap requires no tie wraps or anything to secure it on the line.
The polypropylene is very tough and also "slick", not rubbery, so the fairing rubbing on it slides easily.
The main reasons I like it; I know it works, has been proven over 500 hours, is easy and cheap.
Anyway, I am making too big a deal of it. There are many ways to skin this cat as mentioned by the other folks above. I just hate changing from something I have proven. You always risk introducing some unkown.
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-22-2013, 09:58 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Could you do two layers, one of the 1/4", and cover it with the 3/8" ?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-22-2013, 10:23 AM
JonJay's Avatar
Hmmm, that might work if it isnt too thick overall. I will look at that option. Thanks Mike.
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-22-2013, 05:36 PM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is online now
I would think you could re-size the spiral wrap by wrapping the spiral wrap around something handy, and of the correct diameter, and set it in the oven at 250F or so. Depends on what the material is. Presto - custom size.
Another tip - I globbered RTV in the appropriate location to act as a cushion for the lower edge of the gear fairing. Maybe not elegant, but sure works well.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
