Old 01-20-2013, 05:28 PM
Mopar591 Mopar591 is offline
Default Wing Spar Web replacement
I have a few holes that are miss drilled and now that im using the rv-4 wings on an rv-6 I was wondering if anyone has ever ordered a replacement web and web doubler from vans? I am planning on calling them tomorrow to see if it is even available and the cost.. it seems the last owner only drilled into the left spar.. Hopefully I can disassemble the spar and change the web out without any problems..
Tyler Arnold
Iowa, La
Piper Colt
RV-4 wings and empennage
VAF Supporter! 2012, 2013
Old 01-20-2013, 06:31 PM
JonJay's Avatar
JonJay JonJay is offline
You sure you need to replace the web? A few miss drilled holes may not be an issue. If you do, I am sure Van's will have what you need. If not, the plans show everything you need to fabricate it.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-20-2013, 06:48 PM
Stalldog Stalldog is offline
Default You Are Correct, Contact Van's
Yeah, Tyler, I'd contact Van's to find out what you need, if anything. You might want to send them some pictures of the misdrilled holes so they can give you a better idea of what is required to be safe. As long as your spar caps are good, you might be okay, but only Van's can tell you that.
Whatever you do, protect those spar caps with your life! You know what I mean!
Jim
Lenexa, KS
RV-7A
Old 01-20-2013, 10:18 PM
RV6AussieNick RV6AussieNick is offline
Default Spar damage
Do you have details of the damage, depth, width and height dimensions and of course the location along the spar, there may be a repair you can do, photo's and a call to VAN's might save you a lot of work.
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
Old 01-21-2013, 12:13 PM
Yea the spar caps are fine.. IM sending some pics over to vans this week and hopefully I wont need to replace the web.
Tyler Arnold
Iowa, La
Piper Colt
