Old 01-18-2013, 07:16 PM
jimbo jimbo is offline
Default eyeball lights-pilot report wanted
The cockpit eyeball lights that Vans and Steinair sells found here on Vans site
http://www.vansaircraft.com/cgi-bin/...roduct=eyeball
Just wondered how people like them, if a dimmer is needed or are they so dim to begin with that a dimmer is not necessary.
I see that they are now available in green here: http://www.cockpitlights.com/lights.html
Thanks for any feedback.
Jim
RV9A
Old 01-18-2013, 11:17 PM
p51dplt p51dplt is offline
I've flown a friends -4 with a couple of these pointed at the panel and they work really well. He has them hooked through a dimmer and I always turn them down. I like them a lot, small, compact, and work well. I bet you'd like them as well.
Brant Seghetti
Top Cover Aviation
Nut Tree, CA
P-51, RV-8, 90A, S1
ATP, A&P, IA
Dues Gladly Paid
Old 01-19-2013, 04:41 AM
f1rocket's Avatar
f1rocket f1rocket is offline
I used two of them in my Rocket and yes, I liked them. I prefer them on a dimmer and I used the dimmer often, especially when it is really dark out. I think it is a simple and elegant way to light your panel and would do it again.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 01-19-2013, 06:25 AM
RV6_flyer's Avatar
I have been using them for 15-years. The WHITE light ones use to burn out all the time. The new RED ones are LED. The RED does not need a dimmer. They work but two of them in an RV-6 makes you night legal but not the best if you do or plan to do a lot of night flying.
IF I had to do it over, it would not be my primary panel lighting.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 01-19-2013, 07:21 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default They work...but there are newer alternatives
I've got a couple in the Val, and they still work after 7 years...I think. I never use them because when I fly at night, I wear a little headlamp to light the cockpit when I need light, and the EFIS doesn't need light to read. You can buy LED's on stalks (laptop computer lights) that plug into a USB port that make great map/knee-board lights - and they cost $5.
Everything that we "knew" about cockpit lighting methods and requirements has changed with the advent of "self lighted" instruments (ie, EFIS displays) and the invention of tiny LED's. Don't be afraid to experiment with new ideas in this area - fixed lighting is awfully old fashioned...
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-19-2013, 08:19 AM
RV7ator RV7ator is offline
Default Not Good
I installed an opposing triplet in the sidewalls of a -7. The oval light fields' illumination was both too little and too much, depending on distance, and too pin-point, even several feet from the unit, to properly light the panel. Worse, the reflection bounced right back into the occupant's eyes. All this will somewhat depend on how deep the source is within the round fixture tunnel, but I wouldn't expect even illumination, and/or you'll need a lot of them. The last four projects use glareshield top-down illumination; vastly superior.
John Siebold
Old 01-19-2013, 09:40 AM
f1rocket's Avatar
Wow, I'm really surprised by some of the comments. I must have gotten real lucky on my installation. I'm guessing a lot has to do with where and how you install them. On the Rocket, it's fairly narrow so two, one each mounted in the rollover bar, worked great. On the -9, it may be more difficult to find a suitable location to light the middle of the panel.
I agree with Paul that there's some new stuff to look at. I've seen some very elaborate solutions but experience has taught me that simpler and fewer is better over elaborate and expensive.
Good luck with your choices. Lot's of options to consider.
Randy Pflanzer
Greenwood, IN
Paid through 2043!
