Old 01-17-2013, 01:09 PM
Zero4Zulu Zero4Zulu is offline
Default Prop. Change/Cowl length.
I am considering a Catto prop instead of my Hartzell CS prop because of the high compression engine I have (10:1). My cowl fitting is finished and set for the Hartzell in place. Will the Catto prop with a spacer be the same distance from the engine flange to the front of the cowl as the Hartzell?
Thanks for any help.
Steve S.
Rebuilding RV6A
Scio, OR
EAA Ch. 292
Old 01-18-2013, 01:36 PM
HIIFLY's Avatar
HIIFLY HIIFLY is offline
I fit my RV-8 for a Hartzell propeller and a Vans spinner back plate I gave it 5/16" gap clearance , it was perfect for me . Then I decided to use a Catto 3 Blade prop with a Vans back plate and spinner also used the recommended
2 1/4" spacer . it also fit perfect 5/16" gap . So I would have to say YES !
14 planes owned ,11 bought ,3 built .
RV-8 N808H ,Sold
RV-6 Sold 😔
Old 01-18-2013, 02:03 PM
Excellent! Thank you.
Steve S.
Rebuilding RV6A
Scio, OR
EAA Ch. 292
