Old 01-16-2013, 10:08 PM
ron sterba ron sterba is offline
Unhappy Darn it away! Flywheel belt, forgot to put it on.
Just torqued extension bolts on flywheel and looked at the ground and saw the belt I was suppose to put on,OOPS! Was wondering if I can remove the two bolts and one nut off starter to drop starter down just a bit to slip on belt. Prop not on yet. Wasn't sure if there was something connected into engine (YIO 320) block from the starter other than the three, bolts and nut..Is there a gasket between block and starter.What would be the re-torque values on those three.This looks the easiest way to get the belt on.What your thoughts. much appreciated!
Ron in Oregon
Old 01-16-2013, 11:57 PM
gasman gasman is offline
That procedure should work just fine...............
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 01-17-2013, 06:30 AM
Wayne Gillispie Wayne Gillispie is offline
Don't feel bad, I installed the prop then could not find a way to stretch the belt over the prop. I was just checking the fit...thats it.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 01-17-2013, 09:39 AM
krw5927 krw5927 is offline
As gasman said, that will be fine. The bolt and 3 nuts that hold the starter are 5/16-18 thread. Per the Lycoming overhaul manual, that size bolt or nut should be torqued to 17 ft-lb (204 in/lb).
Kurt W.
RV9A
FLYING!!!
Old 01-17-2013, 12:29 PM
Don Jones's Avatar
Don Jones Don Jones is offline
Default Probably faster......
........and easier to just unbolt the spacer and start over. The bolts on the starter are finiky to get to and will have to come pretty much completely out
to install the belt. (ask me how I know)
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 01-17-2013, 12:51 PM
Kurt thanks for the torque values. I'll give it a try. Don I tried taking the the bolts out but the locktite 242 adds 12 ft lbs to the removal and since I was by my shelf I couldn't hold the flywheel still and break the the bolts loose at the same time. I'm just working my way to setting the upper cowl/hinges so I have nothing in the way of the starter thats why those bolts looked the easiest on the starter. Thanks guys. I guess this OOPS is nothing new.I'm told welcome to the WORLD of engine-omics! Thank God I didn't put the 3 bladed Catto prop on yet. RV9A Ron in Oregon
Old 01-17-2013, 03:06 PM
rocketbob's Avatar
http://www.fennerdrives.com/powertwist-plus/?=
I have had excellent results with these belts on machinery and I see no reason why they can't be used for an alternator belt. They do significantly reduce vibration. I will be using one of these on my Rocket.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-17-2013, 03:20 PM
Lars Lars is offline
Interesting idea. What sort of machinery have you used them on? Do you know offhand what size cross section we would need (yes, I could probably figure it out myself but I'm being lazy)?
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 01-17-2013, 03:27 PM
rocketbob's Avatar
I've used them on my lathe, surface grinder, two mills, and on a drill press. It significantly reduced vibration on my lathe and made a noticeable difference in the finish of the turned part.
N8155F C150 flying
Old 01-17-2013, 04:10 PM
I'm sold. My lathe needs a new belt. Thanks for the info. Nice concept for a spare alternator belt too. Would beat pulling my Hartzell far from home.
Lars Pedersen
Davis, CA
