01-16-2013, 08:24 PM
How to Install the Wingtip Light Lens
I did a search but didn't find anything on this. Does anyone have a good suggestion for installing the wingtip lens? I'm guessing that I should install a #6 plate nut in the top and bottom corners, stick on some weatherstripping around the perimeter, paint the lens around the perimeter to cover the weatherstrip, then screw it down with a FH screw.
Am I on the right track? Thanks.
Al
RV-9A
Allen@AllenRice.net
Started 7/09
First flight 7/8/2015
Love this plane!!
01-16-2013, 08:54 PM
Pretty much - I don't have any weather stripping (yet)  , the clearance is pretty flippin' thin, you'll have to abandon the stripping idea or use something very low profile.
But yeah, you've got the basic idea. A pair of #6 screws.
01-16-2013, 10:02 PM
I did the same. Just the 2 corners. The only issue I had was trying to set solid rivets for the platenut. The joggle in the fiberglass tip for the plexi cover makes it really hard to get those rivets set. I ended up using some pull rivets. Eventually they will be filled and painted over.
01-17-2013, 12:03 AM
AN426A (soft) rivets work very well for nutplates mounted to fiberglass.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
01-17-2013, 07:37 AM
As I recall ....
....The two-platenut approach is what Vans recommends. I think it was outlined in the written instructions (i.e. not on the drawings). That approach worked great for me on one side but not the other. On the 2nd side I had to add a couple more platenuts, likely due to my not trimming/shaping that lens correctly.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
01-17-2013, 01:51 PM
Check this thread
Here is a Vans thread with an interesting technique.
http://www.vansairforce.com/communit...ght=click+bond
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
01-17-2013, 02:28 PM
Another option without using nutplates
Scuff the inside of the wingtip and put a blob of flox where you want the screw. After the flox cures, drill and tap the fiberglass and flox for your #6 screws.
Two screws per lens is fine.
Regards,
Roy
N174RT (RV-7A) first flight 5/31/11, 1780hrs as of August 2020:
Tip-up, Lycon IO-360 EXP, WW 74HRT, AFS 5600T, AF-Pilot, IFD440, SL-30, echoUAT, D100 for backup, CQ1 headsets, CMW E-Lift
Our other riveted aluminum monocoque RV is a 25' Airstream
Past aluminum monocoque vehicles:
N601RT (CH601HDS) First flight 5/03, 1550hrs after flying 8 years: 912ULS, GNS430W, SL-30, D10A Sold
1995 Midnight Pearl NSX w/BBSC Sold
EAA Chapter 105 board member 2010->2015
01-17-2013, 03:59 PM
Thanks!
Thanks for the tips everyone. I'll go ahead and finish them now.
Al
RV-9A
Allen@AllenRice.net
Started 7/09
Love this plane!!
01-17-2013, 04:58 PM
The only thing I'd add is to consider using #8 screws instead of #6.
If I was starting today, there would not be a #6 screw anywhere in my plane. Even using good screwdrivers, I'm getting tired of stripping #6 screws.
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
