Old 01-16-2013, 02:52 PM
ron sterba ron sterba is offline
Talking Here's a FREE app everybody will use.
This free app is one of many free apps for this condition known as noise. Its a sound meter and that's what they call the app. (SOUND METER) If that doesn't work on your smart phone try others, DB level was another. You can check the noise level as you climb,cruise,power off, new mufflers,sound proofing before and after. your buddies plane whatever, washing machine,. I like the sound meter because it has a 15 second graph as the sound is recorded. Let me know if you you like it or found a better app.
Ron in Oregon
Old 01-16-2013, 03:15 PM
jchang10 jchang10 is offline
looks like the same developer "smart tools" has quite a few other goodies including a compass and a vibration meter.
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 01-16-2013, 03:30 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
The apps that only give you unweighted sound pressure level are of little practical value.
Try to find one with at least an A-weighted function if you are really interested in subjective noise levels or to compare with most published noise and attenuation levels.
You may have to pay a dollar or two for that.
Old 01-16-2013, 05:02 PM
Greg Arehart's Avatar
So, suggestions on such an app? I would be happy to spend a couple bucks if I knew it worked reasonably well.
Greg
Greg Arehart
N 7965A
Old 01-16-2013, 09:12 PM
I have found one called SoundMeter+ for $1.99, which appears quite functional.
I do seem to get about 5dBA difference between the same app on Iphone and Ipad, though it does have a calibration feature
If I get a chance I might see how it compares with the precision sound level meters that we have at work.
Old 01-17-2013, 08:49 AM
douglassmt douglassmt is offline
Default dB Volume
Looks like dB Volume has A B C and Z weighting, and is free. Haven't tried it yet.
Bryan Douglass
=VAF= 2020 dues paid
RV-10 N242BD
Old 01-17-2013, 09:37 AM
Skykingbob's Avatar
Default What?
Could all of you type your post louder.....I am having trouble hearing them!
Bob "Skyking" Corriveau
RV-8 QB Reserved N212KB
ATP
CFI/CFII/MEI
Old 01-17-2013, 02:45 PM
scootwoot scootwoot is offline
I used a couple of free sound meters, I find that my mic on my phone gets over driven and maxes out at 80db not much help.
RV-6 (AircraftWraps Sept 15, 14)
Old 01-17-2013, 08:45 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Here are some measurements I took a year ago at different RPM's with a high end sound level meter. Think the mic was about stick height and distance from the panel.
http://www.nti-audio.com/en/products...vel-meter.aspx
Mike W
Venice, FL
N164WM
Old 01-17-2013, 10:08 PM
So, Mike, maybe explain a bit about these graphs. I understand the units etc., but what does the whole thing mean in practical terms (other than obviously wear hearing protection)?
Greg
Greg Arehart
N 7965A
