Old 01-16-2013, 09:25 AM
Captain_John's Avatar
Default Cooling Blast Tube plans
Hey all,
For whatever reason, I cannot find the "Optional DUCT CBT-5/8" Cooling blast tube instructions as mentioned in the baffle instructions.
Does anyone have a copy that they could link me, email me or post up here?
I know how I plan on doing it already but I like to see how Van explains things so that I have all the information available to me that is available.
Anyone???
CJ
The experiment works!
Old 01-16-2013, 12:02 PM
Michael Henning Michael Henning is offline
Thumbs up
John,
I will be heading over to the hangar in a couple of hours (i just finished the blast tubes- alternator, fuel pump, gascolator and mags) and will see if it is in the baffle kit directions. I am close to flying as well here at Nashua (Kash).
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 01-16-2013, 01:41 PM
Mike, sounds like you are neck and neck with me!
Stop by Plymouth sometime, or I will look you up when I go to ASH for breakfast sometime.
BTW, Pat Hatch already emailed them to me so I am all set now. Thank you for looking into it though!
Keep in touch!
CJ
Old 01-17-2013, 08:57 AM
That would be great to hook up with you. Not much info in the directions for the blast tubes.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
