Old 01-14-2013, 06:51 AM
Default Safety wiring worm clamps
Can someone point me to instructions for the proper safety wiring of worm clamps?
There's nothing in AC43.15 about it.
I tried to get some help on the EAA Forums about this but as usual the old men there were too interested in saying you don't need to safety wire worm clamps than answer the question.
On the Reiff preheater instructions, it specifically says the worm clamps on the cylinder bands need to be safety wired. I've seen some examples where the safety wire follows the slot in the screw, but I can't figure out what it's safetied to and my attempts yesterday were clumsy -- to be charitable.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 01-14-2013, 07:11 AM
Wayne Gillispie Wayne Gillispie is offline
I saftied my EGT probes by running through the flat and around the end of the screw sticking out. If not for the extreme temps, I would have roughened the surface, cleaned with MEK or 91% Isopropyl Alcohol then put a dab of red RTV on them. This second method I used on all other hose/scat clamps. You could use it there as temps should not exceed 500F or you would be in big trouble.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 01-14-2013, 08:04 AM
Auburntsts's Avatar
http://avidflyer.wikia.com/wiki/Safe...m_Drive_Clamps
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 01-14-2013, 08:29 AM
Thanks, Todd!
Bob Collins
St. Paul, MN.
Old 01-19-2013, 10:19 PM
Reiff Preheat Systems Reiff Preheat Systems is offline
www.reiffpreheat.com/Instructions-HotBand.pdf
4. Safety wire the clamp screws to insure they will not vibrate loose. If they vibrate loose the heating elements will burn out. Put the wire in the screw slot and around and through the screw housing.
The photos in the previous post show it well.
I safety wire ALL my clamps, not just the cylinder heaters.
Bob Reiff
RV-4 N214RR Lyc 360, CS, P-Mags
EAA Life Member
