01-12-2013, 12:52 PM
Originally Posted by rocketman1988
Is there any reason to not use a drop of loctite on the jam nuts?
Exactly what I do, a drop of loctite and snug them up good, they aren't coming loose.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
01-13-2013, 04:33 PM
This discussion had me thinking about this daily. The inspection is due in February so I decided it was close enough. Yesterday I took the entire interior apart and inspected the entire elevator control system. Everything was good including the safety wire.
01-13-2013, 05:47 PM
My solution
I re-safetied mine today. I used the same approach but deburred the ears more. They really weren't sharp to begin with but rounder should be better. I moved the pushrod back and forth and figured it was better than the first installment. It wasn't rubbing the threads or the ear. I will be checking this more often this year to make sure it doesn't break. Thanks for all the responses. I believe it is good to bring up any anomalies we find during our inspections.
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
01-13-2013, 06:01 PM
Senior Curmudgeon
One of the most underrated benefits of this site.
Thanks for sharing.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
01-13-2013, 06:23 PM
The simple solution
Plus one. This is used on a lot of adjustable ends of hydraulic actuators. The piston with a rod end screwed in can rotate, and this is the safety. Important stuff like landing gear actuators. Could this also work on the flap motor?
Originally Posted by az_gila
Especially if you machined a groove in the pushrod end and used one of these...
http://aircraftproducts.wicksaircraf...origin=keyword
If there is a Mil-Spec equivalent to the Vans rod end, it will be called a "keyway option" to get it with the groove. Aurora uses a "K" in the part number for this option.
01-15-2013, 01:00 PM
Originally Posted by Nictech
I plan to drill a hole in the shaft of the rod end and lockwire it to the cone of the rod with a similar hole as the one in this discussion.
Please don't do that....
Macon, GA (KMCN)
RV-7, Niner Fife Victor
01-15-2013, 07:52 PM
These may help.
01-15-2013, 08:25 PM
+1 You got that right!
Right, wrong, or anywhere inbetween, bring up anything that looks odd.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
01-16-2013, 09:05 PM
Good here
I just opened mine up for my first annual (235 hours). Mine looks fine but I'm going to convert it to the corner-drilled jam nut safety wired to the push tube while it's open - unless someone can convince me there is something wrong with that approach. It sure seems like a better approach, but I'll defer to the experts. Probably put a little locktite on the jam nut for good measure.
Bryan Douglass
=VAF= 2020 dues paid
RV-10 N242BD
01-16-2013, 11:11 PM
Well done!
235 hours in less then 1 year! Well done sir, well done!
David Halmos
RV-10
Flying - 570+ hours
Portland, OR
