Old 01-10-2013, 11:41 AM
Default Cabin Air Exits?
For you folks trying to get your airplanes to go faster, what have you provided for the cabin ventilation air to exit?
Dave
Old 01-14-2013, 08:43 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default easy
I added a bluff body outlet where the aft inspection panel is normally mounted. Seem to work OK for me - you could install such an outlet on the underside of the fuse near the tail if desired. Might think about a doubler around the hole you would cut if you pick this option.
For an example (sizing and design), have a look at any Beech 18.
Carry on!
Mark
