Old 01-09-2013, 09:31 PM
idleup idleup is offline
Default AeroLED NS-90 Electrical Question...
In the manual for AeroLED it states that the peak load is 2.4A for each strobe. The duration of the this load is quite short 0.33 seconds. The wiring for each strobe is 20AWG(Shielded). What size fuse should I use to protect these three strobes? If I add up those three loads it is 7.2A so I thought maybe a 10A fuse. But since the duration of the load is so short I am wondering if I am putting too large of a fuse...
Anyone else with this setup could you please advise?
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 01-09-2013, 10:11 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default Read the current instructions
http://www.aeroleds.com/LinkClick.as...6270&mid=13206
The directions here, right on the wiring diagram..... Budget 3A per strobe and use a 7A or 10a breaker (presumably for two vs. three strobes.)
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 01-09-2013, 10:17 PM
Thanks Derek, that is what I needed.
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
