01-09-2013, 09:15 PM
Screw spins in Platenuts
Am trying to remove the factory installed screws from the 716 access ribs but they just spin in place. The heads are not stripped and I can get a good seating with philips screwdrivers. The screws spin with some resistance but do not back out of the holes. Any suggestions how to remove other than drilling out?
01-09-2013, 09:29 PM
Any way you can get under the head of the screw a little while trying to back it out?
Tyler Arnold
Iowa, La
Piper Colt
RV-4 wings and empennage
VAF Supporter! 2012, 2013
01-10-2013, 09:00 AM
Not so far but I'm going to try again with a helper. Maybe we can get a razor blade under the head while turning the screw.
The ribs flex when screwdriver is pushed into the screw head. Without that pushing, the screwdriver slips from the screwhead during turning.
Another idea I'm going to try is pushing on the back of the screw with a pin punch.
Since the screw head isn't countersunk, I also thought of locking vicegrips on the screw head to turn and pull. Not sure if my vicegrips are that precision.
If neither of those ideas work I'll likely try drilling.
Thanks for your suggestion.
.....Victor in Niagara Falls
01-10-2013, 09:06 AM
Senior Curmudgeon
Welcome to VAF!
Victor, welcome to the good ship VAF.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
01-10-2013, 10:10 AM
screw size
Any chance you've got 6-32 screws in 8-32 platenuts?
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
01-10-2013, 10:39 AM
Or 10-32 platenuts for 8-32 screews?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
01-10-2013, 10:47 AM
You can take a small vice-grip and clamp it on the head of the screw to give you some back pressure to back it out. Not fun.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
01-10-2013, 11:06 AM
Maybe a careful drop of super glue on head
to attach something you could pull on while turning--you only need a turn or two to lift the head enough to grab with pliers.
Bob Marshall
01-10-2013, 11:11 AM
Drill a deep hole, use an easy-out so that you can pull while turning. If I could get something on the back side to push on the screw, of course that would be better.
Good judgment comes from experience, and a lot of that comes from bad judgment.
01-12-2013, 05:09 PM
In the future don't assume I know of which I speak
Today, having removed the wing, I was able to view the offending screws from a different angle and caught a glimpse of the edge of a regular nut instead of a platenut. That explains why the screw turned without backing out. With a wrench holding the nuts, the screws turned out without issue. Now I feel kind of silly  Thanks for your suggestions though.
