Old 07-24-2006, 11:28 AM
Paul Thomas Paul Thomas is offline
Default What extra to order? (RV-7 Emp Kit)
Hello everyone,
I'm ordering my 7 empennage kit and wondering what extra things I might need. I've heard people suggest that you always need extra rivets and things. Is there some kind of list to what extra are needed? Should this be ordered through Van's or another company?
Thanks all,
Paul
Old 07-24-2006, 12:12 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Paul,
I found that I needed the following from Van's:
1) OOPS Rivets (I ordered all sizes)
2) ProSeal for the trailing edge of the rudder. I ordered the 3.5 oz size which was nice because it came in a semco cartridge. Very easy to mix as there is no measuring. On the downside, I didn't use very much of it at all, so it was a waste. The 1 oz size should be plenty.
3) MK-319-BS blind rivets. I used some of these on the TE for the rudder because I couldn't get a squeezer in there. I ended up short when I came to the trim tab.
4) Extra trim tab skin(s)
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 07-24-2006, 02:43 PM
It's in the mail!
Thanks Mike.
Old 07-24-2006, 02:50 PM
rickmellor rickmellor is offline
For me it was just the parts that I messed up. Like the aft spar for the left elevator where I dimpled the top row where I should have countersunk. Just small stuff like that.
What tools did you get? I swear buy the Avery RV tool kit (don't drop any clecos even if you're doing the QB. you'll need them). Also, don't think twice about the pneumatic squeezer. It's expensive but after you get it you'll wish you'd had it all along.
RV7A (aborted in 2007 )
Brooklyn, NY
Old 07-24-2006, 03:26 PM
lucky333's Avatar
lucky333 lucky333 is offline
Default Nuts n Bolts
Literally,
Wicks has AN nut and washer kits with assortments in a divided plastic boxes. I also ordered 5-10 of every AN-3 and AN-4 bolt, with and without shank holes. Added 100 each of #6 and #8 nutplates as well as cotter pins and a few other little hardware items.
Now, when I drop some dinky piece of hardware, I don't have to get on all fours and search through all the junk on the floor. Saves a bunch of time.
John
John Oldenkamp
RV-7A project for sale
VAF Paid 2018
Old 07-24-2006, 03:43 PM
It looks like I'll be picking up the planetools kit.
Right now they're offering the DRDT2, pneumatic squeezer and shipping for free (of course you pay for it on the rest of the kit )
Old 07-24-2006, 04:36 PM
cobra cobra is offline
Im a bit confused here- Im just finishing my rv9 empannage and did not need any of the extra items listed, including rivets & air squeezer. Is the RV9 different than the 7?
The only things I sorta missed (could have used once) were a #10 dimpling die and longer yokes on my hand squeezer, none of which were difficult to work around. I did have to make a few special bucking bars out of assorted garage tools (pry bars, sheet metal dolly, heavy metal pieces welded together and polished). I already had a hole saw kit stashed in my drill bit drawer.
BTW, I highly recommend the DRDT-2 dimpler, band saw, a 1" belt sander, and a full set of numbered drill bits! A spring-powered center punch has been handy a number of times, especially for drilling out bad rivets.
Having several battery-powered drills has been handy. One indispensable tool, that was never mentioned, is a sharpened and polished tiny ex-screwdriver used to align the predrilled holes for clecos.
Mike Parker
RV-9a under construction
w/Mazda rotary- Renesis
Old 07-24-2006, 05:43 PM
N674P N674P is offline
Except for the fiberglass, my 9 emp is completely done. I don't recall needing a #10 dimple die anywhere - did I miss something?
Or maybe over the course of the last 6 months I dealt with it, moved on, and forgot it...
Johnny Pruett
VAF #601
-9 fuselage standard kit on hand
Slooow build wings still in progress...
Old 07-24-2006, 05:56 PM
osxuser's Avatar
osxuser osxuser is offline
For my -7 I could have used offset #3 and #4 rivet sets, but those might come with most tool kits, I just put my own tool kit together.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 07-24-2006, 06:36 PM
Scott Will's Avatar
Scott Will Scott Will is offline
The #10 dimple die is used for the screws that hold the lead counterweights on. That's the way it's done on the -7 (rudder and elevators) and I can't see it would be any different on the -9. Especially the rudder.
Scott Will
http://will2fly.com
CFI - CFII - MEI
FLYING RV-7A IO-360 @ KPDK
