Old 01-09-2013, 11:14 AM
larrynew's Avatar
larrynew larrynew is offline
Default Orphan wires in PP Alternator?
I have a Plane Power alternator but don't need to use the optional alternator out wire. I've been studying wiring and Bob's book and even NASA workmanship standards (which have some really good pictures of proper terminal crimps and solders sleeves and more) but haven't found whether it's better to leave the wire in the plug and crimp on an end splice or just take the wire out of the plug.
The d-subs and power plugs on the VP-X aft of the firewall leave open holes. Will an open hole firewall forward in the alternator plug invite contamination?
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 01-09-2013, 03:31 PM
cjhammes's Avatar
cjhammes cjhammes is offline
I have the same PP alternator. Did not need the extra wire. I left the connection in the plug and just cut it, leaving ~ 6 inch lead, curled the end over and heat shrink. Then routed the small length along with the red Alt wire. Doubtful I'll ever need it. I believe the instructions say to simply cut it off if not needed.
Old 01-09-2013, 08:19 PM
Wayne Gillispie Wayne Gillispie is offline
Default Save weight
remove the pin from the connector.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 01-10-2013, 07:12 AM
Walt's Avatar
Walt Walt is offline
I would cap it and tie it back into the "harness", the extra wire helps to support the other wire.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
