Hartzell Governor and MT Prop interface:
After some exhausting research, I found that the new "S" series Hartzell governors will not produce enough presssure to operate the MTV-15 (MT) props. Also, there is a known defect in the MT Governor, which requires an upgrade to fix to keep the prop from "hunting" called the "F" mod (now the "G" mod, about $800.00 from MT USA. The newer style Hartzell governor will work, but requires placing an .032 washer on top of the relief valve spring to up the pressure output about 50 psi. The MT propellers require about 320-240 psi, and the hartzell propellers require only about 260-280 psi. I received the data from hartzell, Wings West governor shop, and MT. Hopefully, this will keep others from having to endure the research project I just concluded on my governor problems.
Regards,
Gary
