Old 01-09-2013, 12:30 AM
Taildrgr's Avatar
Taildrgr Taildrgr is offline
Default Tip-up Canopy Guide
I have seen pictures of a tip-up canopy guide made of delrin that aligns the rear latches as the canopy closes.
Does anyone have a cheap source for small pieces of delrin?
The cheapest I can find is Grainger at $70 for 7/8 x 12 x 12. I would prefer a smaller size if possible. The guide is about 7/8 x 1 x 4 and of course would need 2.
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
Old 01-09-2013, 04:56 AM
jim plaster jim plaster is offline
Default delrin blocks
Check out composite cutting boards at your local hardware store.
Old 01-09-2013, 06:11 AM
Taildrgr's Avatar
Great idea! Thanks.
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
Old 01-09-2013, 06:28 AM
rzbill's Avatar
rzbill rzbill is offline
I think there are multiple materials that could be applicable.
Delrin Acetal (as already mentioned)
Nylon (any version)
UHMWPE (the likely material in the kitchen cutting boards suggested above)
PTFE Teflon in high durometer form.
I'm sure there are other solutions too.
I think mine are UHMWPE but not sure since I had all the above materials in the scrap bin at the time.
Bill Pendergrass
ME/AE '82
Old 01-09-2013, 07:32 AM
Greg Arehart's Avatar
Also try a local plastics shop. They often have a scrap bin with cheaper pieces.
Greg
Greg Arehart
N 7965A
Old 01-09-2013, 08:12 AM
Don Jones's Avatar
Don Jones Don Jones is offline
Default I used these!
Works nice, already made, just install them.
http://www.bullerent.com/CanopyGuide.htm
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 01-09-2013, 08:59 AM
bruceh's Avatar
bruceh bruceh is offline
I bought a 12" x 12" chunk that is 3/4" thick from McMaster, then just used the table saw to make appropriate sized slices of the material. I've still got a bunch left over, so if you want some of it, let me know and I will get rid of this stuff for shipping & handling charges.
Bruce Hill
2020 VAF donator
Old 01-09-2013, 09:29 AM
Taildrgr's Avatar
Default Canopy Guide
Thanks, Bruce.
PM Sent.
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
Old 01-09-2013, 10:33 AM
Rupester Rupester is offline
Default Nylon works ...
I used 1/2" thick nylon that I got from one of our A/C suppliers (Spruce, as I recall). The stuff is a BEAR to cut. I about destroyed a friend's bandsaw blade cutting the pieces to the right shape ...the nylon gets sticky as it warms and the blade binds like crazy, heating the nylon up even more. Nevertheless, the finished guides work well.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 01-09-2013, 10:58 AM
bruceh's Avatar
Here is the material that I used. Commentary from my web site photos attached.
This is UHMW plastic, 1"X4", 3/4" thick, with the corner cut down.
I cut this material with the table saw, then used sand paper of progressively smaller grit to get this all smoothed out.
You could put these either both on the outer side (as shown here) or both on the inner side of the latch lug. My canopy wants to spread out slightly, so I'm going to mount this on the outer sides. I'll put 2 counter sunk screws through this plastic to mount it to the roll bar. Getting a wrench inside the roll bar to tighten the screws will be impossible, so I plan on making a small plate with nutplates on it to secure this.
The guide block installed on the roll bar. I had to open up the slot for the lower latch lugs just a bit. It is a very tight fit, but with the guide blocks in place the canopy comes down nicely and into closed position smoothly.
Bruce Hill
2020 VAF donator
