  #11
Old 01-06-2013, 05:40 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Richard
If you know Chad and Glen down there at YSBK......they would love to learn from your experiences too, they have the same drama even when they believe they followed the instructions.
Hmmmm Whelan's do work nicely
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 01-06-2013, 05:48 PM
rwtalbot rwtalbot is offline
Yes David, We have 3 RV's at YSBK with the same problem. Two have been installed exactly as per the instructions (as best as we can determine). The other has not been and is (understandably) worse.
The Whelens do work well until the power supply for the strobe fails and they want $600 for a new one.
I am going to follow this through with Aeroleds. My personal view at the moment is that my current installation is far from optimal for NVFR/IFR ops.
Cheers
Richard Talbot
RV-7A
Sydney, Australia
Old 01-06-2013, 06:44 PM
rv9aviator rv9aviator is offline
My aeroleds have worked perfectly with no issues.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
"It's a brutal struggle for the biscuit."
Old 01-06-2013, 06:45 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default Closely follow the Aeroled directions...
Originally Posted by ILikePike View Post
Stephen, are you saying the 1st sketch is incorrect? I was planning to do it this way but I am putting the black wire from the light through the connector then to local ground for easy removal of the light.
The aeroled diagram shows connecting the shield to ground back at the source (VP-X in my case). Is this correct? Isn't there some guidance to only connect sheilds at one end?
The most critical issue with these lights in reducing emitted noise into the radios and intercom is returning the ground to the case with a short run... this makes a BIG difference. I used a handheld radio to evaluate the noise from the strobes and position lights and the difference is quite remarkable.
Here is a shot of the wingtip connection for reference.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 01-06-2013, 08:55 PM
ILikePike ILikePike is offline
Stephen, where did you ground the shields on each end?
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2019
Old 01-06-2013, 09:14 PM
Default Shields
Firewall and outboard rib.
Stephen
ORCA Flight
Race 771
margarita!
Old 01-06-2013, 09:33 PM
grayforge's Avatar
grayforge grayforge is offline
Lots of ideas here. I'll see if I can get AeroLEDs to weigh in. :-)
Speed Is Life
VAF Donation made: 1/28/2020, My RV-7A Build Log
Old 01-06-2013, 11:55 PM
Richard Connell Richard Connell is offline
Im assuming I'm not the "other" as I'm very sure I've followed the instructions to the letter, including the extensive details on the Aeroleds site. Still, COM frequencies around 120 break squelch - which makes YSCN problematic! Let me know if you come up with anything!
Cheers
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 01-07-2013, 12:39 AM
ColoRv's Avatar
ColoRv ColoRv is offline
These problems and they cost HOW MUCH? Mercy....
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 01-07-2013, 04:33 AM
RV10inOz's Avatar
Cheers
hahahhahah
Chad and Glen probably assume they are not the other....how many are there?
Glen tells me he followed the instructions carefully, of course EVERYONE will say that but maybe some subtle misunderstanding has crept in.
A mate GerryinOz up here is about to pull the trgger on these or Wheelans and I am doing his electrics with him, so it matters a bit to me now too.
Richard, give me a call if you get a moment....I dont have your number it seems.
Cheers
DB
David Brown
