Old 01-06-2013, 12:25 PM
pa38112 pa38112 is offline
Default Where to pick up manifold pressure ?
The Vans MP gauge says to pick up the pressure off of the #3 Cylinder; however, I have a primer line located on that port. Is there any reason why I can't or shouldn't take the manifold pressure off of the #1 Cylinder instead ? It is a lot more work to re-pipe the primer and the hose that came with the Vans PM instalation kit seems the perfect length to come off of #1.
Old 01-06-2013, 12:32 PM
flyinga flyinga is offline
Any of the like ports will work; cylinder doesn't matter. Use a restrictor type fitting.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 01-06-2013, 06:22 PM
aerhed aerhed is offline
If you have a primer then you have a carb. So, you can also use the injector port.
Actual repeat offender.
