Old 01-05-2013, 01:17 PM
bluemaule bluemaule is offline
Default Tube source?
Need a tube for RV-7 main. Tire size is 5.99 x 5. What brand is preferred and what source?
I guess I let the psi get too low. What pressure should I run?
Old 01-05-2013, 02:06 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default Vans...
I get mine from Vans...
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 01-05-2013, 02:28 PM
Kyle Boatright Kyle Boatright is online now
Michelin airstop tubes from Desser are my choice. I run bout 35 psi in the mains on my RV-6.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-06-2013, 05:51 AM
pierre smith's Avatar
Default Yep
I'm with Kyle and Desser is in Tn. 323 721 4900. www.desser.com
I run their certified recaps on my Air Tractors...$160 vs $400 for new ones and their recaps last way longer...harder compound.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-06-2013, 07:48 AM
rocketbob's Avatar
http://wilkersonaircrafttires.com/
Quite a bit cheaper than Desser on retreads and just as good. Just got several sizes of tires last week and they were $56.00/ea. All were Goodyear retreads.
Same price as an inner tube!
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-06-2013, 01:05 PM
Default Thanks for the help!
I thought my landings were getting a lot better, with no bounces. Guess the improvement was due primarily to low PSI... I'll have to get back to 30 PSI and see if I've improved at all...
Old 02-24-2014, 04:49 PM
Bevan Bevan is offline
Default Tube pricing out of whack
Van's price of the inner tube for the 5.00x5 tires is more than 5 times the cost of the tube for the 4" nose wheel (which is a far less common size). Further, Michelin airstop tubes are made for everything from aircraft to bicycles to motorcycle tires with the aviation sizes 5 to 50 times the cost of the others. Since tubes are a little flexible in sizing, I wonder if there is tube made for another application (go-cart, or ATV etc) which is close enough to a 5.00x5 tube to be used successfully on our aircraft. Anybody researched or done this?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
