A radiant heat shield often has merit, depending on gascolator proximity to an exhaust pipe. The shield is usually mounted to the pipe. They're easy to make in any length you desire.
Actively cooling a gascolator is inefficient because of the low temperature delta. The air coming down a blast tube will be 100F+ on a warm day. It might even be warmer than the incoming fuel temperature. In reality you're not cooling it, but rather protecting it from lower plenum heat sources...air and radiant. You should be able to do as well with an insulation sleeve and/or a radiant shield
Dan Horton
RV-8 SS
Barrett IO-390
