Old 01-03-2013, 08:31 PM
MJarreau MJarreau is offline
Default Grading Scratches
How does one determine if a scratch is superficial or needs to be polished out (newbie)? Is polishing performed?
TIA,
Michael
DUES REMINDER: JAN 2021
Old 01-03-2013, 08:38 PM
smbrown smbrown is offline
When I visited Vans in 1994 (Ken?) indicated a scratch was something that your fingernail would stop in... anything less was not a considered a scratch that needed addressing. Interested to see if this has changed since.
Old 01-04-2013, 07:40 AM
That's what the Nuvite folks told me too. Polishing won't help a scratch that'll catch a fingernail (actually it SORT of will....if you polish it several thousand times, I guess).
I sanded a few scratches on the plane when I just did the polishing, then finished it with a 1000 grit grade and then polished. There's also a few that I didn't both with sanding, that I polished, that got a little better, that I'll deal with later.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 01-04-2013, 10:08 AM
rzbill's Avatar
rzbill rzbill is offline
Yeah Bob.
My first polishing just showed me the places I had to work on more (the spots with scratches)
You are right that you can polish scratches enough to make them a lot less obvious. I had to do it recently because I ham handed the cowl installation and scratched the **** out of the forward side of the cabin. Cussed a lot. Polished to a non noticable state fortunately.
Bill Pendergrass
ME/AE '82
Old 01-04-2013, 10:33 AM
Philosophical quandary: if the scratch is non-noticeable and no one there to tell does it still exist?
The biggest downside to DIY projects for me, I know where all the flaws are located.
Old 01-04-2013, 04:25 PM
That's what I thought when I was building. I can't polish because of all of the blemishes.
Now that I'm done, to be honest with you, I cherish the dings and dents as much as any other part of the plane. There's a story to each one of them and they were part of the journey too.
If anyone ever gives me garbage about it, I usually say, "how's your plane?" And often that shuts them up.
Bob Collins
St. Paul, MN.
