Old 01-03-2013, 08:06 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Unhappy Flow EZY Filter purchase ?????
I tried to order a filter for my RV3 today and they said they can't sell a filter for an airplane ! Not surprising, but how do you get a filter from these folks when you want to just pay with credit card? There forms only ask for a purchase order, and the guy on the phone acts as "the guard at the gate".
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 01-03-2013, 08:16 AM
rocketbob's Avatar
Note to self: when asked if purchasing an item what its for, always say its for your tractor.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-03-2013, 09:56 AM
kevinh's Avatar
kevinh kevinh is offline
I remember when I was using Sika adhesive to bond my canopy. I had some questions about the application, so I called them and spoke with a very helpful applications engineer.
I described my problem and forgot to use the 'tractor' and foolishly said canopy.
The engineer said, "I'm sorry this product is not for airplanes and I can't help you with that application. It is however used for high speed trains, are you sure you aren't building a train?"
I replied with, "Oops - I must have misspoke. I have a question on how to apply this to my bullet train." He was then quite helpful...
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 01-03-2013, 10:12 AM
Jeff A's Avatar
Jeff A Jeff A is offline
You should be able to order online without talking to anybody (unless you are trying to special order something). Put "1234" in for the PO number. I haven't ordered from them in a while, but don't recall any problems....
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 01-03-2013, 04:14 PM
Default New website
The general manager sent me an email with a new website address . No questions / no problems, just order your stuff and pay with credit card on-line.
www.flowezyfilters.com
Larry DeCamp
Clinton, IN
Old 01-03-2013, 04:24 PM
Jeff A's Avatar
Good to hear. Now, remember to tell the person at NAPA that the alternator you need is for your Suzuki Samurai.
Jeff Atkinson
Old 01-04-2013, 12:19 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Don't tell a fib
Just tell the truth - it's for your RV.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-04-2013, 05:40 PM
rv7charlie rv7charlie is offline
What's so special about their filter(s) that makes them better than stuff from Summit, etc? Which model are you using?
Old 01-04-2013, 05:45 PM
chaskuss chaskuss is offline
Be sure to specify that you want Viton O-rings on your filter. I believe that Nitrile O-rings are standard issue. Nitrile works great with 100LL, it shrinks in the presence of auto fuel. They have that as an option. Just an FYI
Charlie
Old 01-04-2013, 10:49 PM
Lars Lars is offline
Russell and Earl's (among others) both make filters similar to the Flow-Ezy 3000 series, in comparable mesh sizes and flow rating. They are a lot cheaper- like, 1/3 the price. Drilling down on Summit's site, they are supposedly rated for alcohol (thus likely Viton o-rings) but I wouldn't trust that as far as I can throw my credit card. Ok, poor analogy. I would call the manufacturer to get a confirmation on o-ring material, or plan on buying known Viton o-rings before installing. You can save a lot of money that way, probably because you'll be getting filters made in a country whose name starts with C. Not that that's a bad thing, but the Flow Ezy filters are made here.
Above is mentioned because I'm doing a major make-over of a fuel system on a long-time automotive project (thus I can say honestly that I'm getting a filter for motorsports use, though I may need a "spare" just in case) and after seeing a vast difference in pricing on various components including fittings, I started researching country of origin.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
