Old 01-03-2013, 08:03 AM
gtmule gtmule is offline
Default Removing spray adhesive from firewall
All,
As part of my panel upgrade, I'm removing the original builder's firewall insulation and, most importantly, glue. Anybody have any ideas on this? It appears to be 3M or similar spray adhesive, and goof off (that I happened to have) had absolutely no affect. WD-40, goo-gone, kerosene, Acetone, MEK, etc are all possibilities, but I was looking for some specific experience.
Chuck
Macon, GA (KMCN)
RV-7, Niner Fife Victor
Old 01-03-2013, 08:12 AM
rocketbob's Avatar
Removall SV-35 PMA is a paint stripper I've used that will remove adhesives nicely. Its not nasty stuff and wont cause corrosion/embrittlement. Wicks used to carry it by the gallon, and it appears they no longer do so.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-03-2013, 12:02 PM
Stripper is what I was thinking of. Anyone tried the Stewarts Ekostrip?
Macon, GA (KMCN)
Old 01-03-2013, 12:17 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
This is the passenger side of the firewall correct???
May I suggest you make sure to have lots of fresh air moving around in there while you are tucked under the panel fussing with solvents in such a tight space.
A supplied air respirator would be wonderful.
If you end up using a petroleum based solvent, DO NOT use O2 for breathing, should you happen to have the plane rigged with O2.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-03-2013, 12:39 PM
Yes, that was my reason for asking about ekostrip
Macon, GA (KMCN)
Old 01-03-2013, 12:45 PM
Mike S's Avatar
Senior Curmudgeon
Default Goo Gone
I have had good luck with Goo Gone for many years.
http://googone.com/GG-Browse-Product...omotive-Garage
But, I would still go with lots of fresh air circulation at the least. Just an old fireman's habits.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 01-03-2013, 01:28 PM
az_gila's Avatar
az_gila az_gila is offline
This stuff works well on old, cured glues and even smells acceptable being citrus based -
https://www.aircraftspruce.com/pages...adhesremov.php
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-03-2013, 06:09 PM
N15JB N15JB is offline
Gil,
Do you know if that stuff is OK for our windows? Thanks.
Jim Berry
RV-10
Old 01-04-2013, 12:40 AM
az_gila's Avatar
Originally Posted by N15JB View Post
Gil,
Jim Berry
RV-10
Should be OK... MSDS says it only has Citrus Extract and Propane (propellant) in it -
http://multimedia.3m.com/mws/mediawe...9lxtD7SSSSSS--
But if you are removing adhesive from plexiglas I would use kerosene or isopropol.
Gil Alexander
Old 01-12-2013, 05:04 PM
Just a followup. Goof off (the real stuff, not their "degreaser" stuff that I accidentally bought) is going the trick. I think it's mostly acetone or alcohol or something, with maybe some citrus oil or something in it. I never tried straight acetone, although denatured alcohol didn't make a dent. Big box fan on high sitting in the seat blowing under the panel clears the fumes out adequately.
Macon, GA (KMCN)
