Old 01-03-2013, 10:48 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Anyone else unable to access this link??
It didn't come up for me either Mike
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-03-2013, 10:54 AM
Auburntsts's Avatar
The entire site seems to be down right now as my normal Matronics bookmark isn't working either. In any event, the pics are the same as the ones Doug posted on the VAF frontpage.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 01-03-2013, 10:55 AM
WenEng WenEng is offline
Default I think the server is down, not that particular link..
I'll wait awhile and try the server again. I couldn't even get to matronics.com.
Matt's probably working on kit log pro updates and doesn't know his server is down
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
Old 01-03-2013, 11:26 AM
Toobuilder's Avatar
Originally Posted by David Paule View Post
I bought one of these http://tinyurl.com/adewcw2 to measure the running torques on nuts...
FWIW, general practice in the military is running torque is only required on fasteners larger than 1/4 inch. Anything smaller uses the "hand tight" method - in other words, if you can turn the nut through the locking feature by hand, you discard the fastener.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 01-03-2013, 11:32 AM
Steve Barnes Steve Barnes is offline
Default De Ja Vu
This exact thing happened to me in my 6. I noticed on one flight when I was in Phase One (about 20 hours) my stick in pitch had another 1/8" play. I was very uncomfortable and got on the ground fast. I promised my self before I landed, that I would not fly again till I found the problem. The problem was very subtle. It was so subtle that had I not had so many hours in the plane, I would never have recognized it.
I started my investigation by tapeing the elevator to the horizontal stab. (my assumption was that a rod end bearing had failed WRONG) Everything checked out fine till I removed my floor and inspected the first rod end bearing to the push tube underneath my sticks. There was NO NUT or WASHER on the number 3 bolt that went through the rod end bearing. The bolt had partially slipped out and was wobbeling since I no longer had a double sheer attach any more.
So how did this happen and why didn't anyone catch it? I installed my wing leveler on top of the attach point and it was totally hidden from view. Even though I had no less than four inspections by highly qualified people, no one used a mirror and inspected that particular attachment. In fact I did such a thorough job of inspecting and correcting before before any one else inspected that there were only a few minor squaks.
If I had continued flying the plane and ignored a seeming minor problem, at some point I would have had A VERY BAD DAY.
Hopefully these 2 events will save someone else of the same event or worse.
Steve Barnes "The Builders Coach
Old 01-03-2013, 11:53 AM
Bevan Bevan is offline
Steve, do you think the nut and washer were never actually installed, or do you think they backed off somehow?
Bevan
"no one is smarter than all of us"
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 01-03-2013, 12:41 PM
Rick S. Rick S. is offline
There are several "Jesus" bolts in the RV series and this is one of them.
In all my years of working with nylon and metal lock nuts, if it was servicable when it was installed and properly tightened it was not going to back off and I never saw one back off. In the RV-10 it is not difficult to inspect IF you have ALL the panels off for inspection.
Rick Sked
Old 01-03-2013, 02:47 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
True, but if you look at the drawings, there is a jam nut, and it is safety wired.
Is this only in the -10 plans? I don't recall ever seeing the bearings having safety wire. Thanks to Adam P. for posting the image of the plans. You can clearly see the safety wire around the bolt where it could pull out of the pushrod. I don't think that's in the -7 plans.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 01-03-2013, 03:00 PM
Default Never installed
Bevan, There is no way that a properly installed nut would ever come off.
Old 01-03-2013, 03:05 PM
N427EF N427EF is offline
Default Safety wire
Safety wire is installed to keep the pushrod from rotating
For whatever reason on the RV10 only.
It has no bearing on the safety of the nut and bolt.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
