Denny,
I can't give knowledgeable advice from over 2500 miles away. It helps to be able to see what your choices look like. That said, I can give you some info about two of those engines.
The first engine, the IO-360-A3B6, has a counter weighted crankshaft. This is used on certain model aircraft where propeller resonance is an issue. These engines usually weigh about 20 to 30 pounds more than a non counter weighted engine. On top of that, the counter weighted crankshafts cost more and are not as easy to find used.
The third engine [IO-360-C1D6] has horizontal fuel injection. Unfortunately for you, it faces rearward. That won't work in an RV. It also has a counter weighted crankshaft. [heavier]
With the 8, you could use the IO-360-C1D6 engine, IF you modify the sump, or replace it and all 4 intake tubes with ones from an IO-360-Axx series. Using the IO-360-Axx series sump and intake tubes will allow that engine to be used on most RV models. The IO-360-Cxx series sump will NOT work with the 8A.
Bill Wightman posted an excellent article on how to modify the sump from an IO-360-Cxx series for use on an RV8. The thread also shows why it won't work with an 8A. It starts about the middle of the page linked below
http://www.vansairforce.com/communit...ht=sump&page=3
With the first engine, you can decide whether to purchase a counter weighted or non counter weighted engine, since it will be used experimentally.
Charlie
PS On the IO-360-C1D6 engine, you might be able to swap that rearward facing sump/intake tubes with a Velocity builder who has an IO-360-Axx series engine. He needs the rearward facing sump/tubes for his project. You need a forward facing horizontal sump/tubes to use an angle valve IO-360 engine.
