Old 12-31-2012, 09:51 PM
Michael Burbidge Michael Burbidge is offline
Default Garmin GTX 327 wiring questions...
I'm building a frugal panel with mostly round gauges from Vans. I have a Garmin GTX 327 transponder, and a AK-350 altitude encoder. I have a few questions about pins in the connector that drive functions on the transponder that I will not be using. The question is can I just leave them unconnected, or do they need to be tied to ground or power? I've read the installation manual and it is unclear to me. Here are the pins that I'm wondering about:
Airborne sense (squat switch)
External suppression
External standby
External ident
RS-232 IN 1
RS-232 IN 2
Thanks for any info you can provide.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 12-31-2012, 09:55 PM
Brantel's Avatar
Brantel Brantel is offline
Just leave em disconnected if you are not going to use em.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-01-2013, 07:47 AM
AltonD's Avatar
AltonD AltonD is offline
If you have a gps, feed the data to the 327. The auto on/stby feature saves me embarassment.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 01-01-2013, 08:36 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Michael,
The GTX 327 will auto-sense that the aircraft has gone airborne and automatically switch from STBY to ALT even without a GPS input if you configure Auto Standby to ON.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 01-01-2013, 12:20 PM
tim2542 tim2542 is offline
Default GTX327
Thanks for the info Michael
I didn't know it could sense flight without a serial connection! Any idea how it knows the aircraft is in flight without this info?
Also, is there any hope for 327 users to get extended squitter added in the future? I understand the 330 can be updated.
Thanks!
Old 01-01-2013, 12:51 PM
g3xpert's Avatar
Post
Thanks!
Hello Tim,
The GTX330 was designed to support an extended squitter option, but the GTX327 was not.
I should have mentioned earlier that Alton is correct that GPS can be used (when available) for airborne determination.
The GTX 327 uses the following data sources, in order of priority, to determine if the aircraft has become airborne:
1. Weight on wheels (squat switch)
2. GPS ground speed increase
3. Airspeed increase
4. Altitude increase
For a GTX2327 with nothing but an altitude source, it uses altitude to determine airborne status.
Steve
Garmin G3X Support
g3xpert@garmin.com
