Originally Posted by gmcjetpilot
Hummm I might consider doing the same to save another hole in the panel, especially with a "optoisolator".  Did you really use a optoisolator? If so how did you wire that in? What aux scale factor and offset did you use?
PS don't feel bad TShort, I had to look up "optoisolator" also. My suggestion is google and Wikipedia.
Yah, I did. But like I said, mostly because I didn't want to deal with relabeling my pretty panel. If I was going from scratch, I'd probably put in the bulb and be done with it. I forgot to explain the context on wiring up the isolator, because my original post/thread intent was just to make people aware of a potential difference (hah!) between the Van's and PP variants.
In fact, I just checked the
Wikipedia link (thanks George) and it is a really good description of approximately what I did. I just drive the LED from the 12V output on the PP alt, and hook the transistor up as a gate to pull the EIS input between 4.8V (provided by the EIS) and ground.
I picked R2 as something largish (20Kohm? - don't remember) - the exact value doesn't matter, but smaller values will consume more current just for the pull up resistor. Ohm's law IR=V, where V is 4.8V.
For R1, it is operating as a
current limiting resistor. To calculate that value, refer to the datasheet for your particular isolator. It will say something like 3.4V @ 20 mA. Approximately, this is specifying the ideal current and voltage for the LED to operate at. Either use ohms law for a series resistor or plug these two numbers in with the 14.1V typical max voltage for the alternator into one the common
online calculators.
I would quote exact values, but they are in my notebook at the hangar - besides, they depended on the values I read off the back of the particular isolator I was able to find at the local electronics part megamall (gotta love Silicon Valley).
For AuxSF and AuxOff, I left them at the defaults of 100 and 0. Then powered the plane up (but did not start it). Verified that the alternator had pulled the LED on with a multimeter and saw that the EIS was showing a value close to zero (15ish). The I started the plane up and saw that the EIS was showing something close to 90 (because the transistor in the isolator wasn't pulling to ground). I then repeated same test, but start the plane and never bring alternator on, see that EIS is reporting 90ish. Therefore I set the EIS warning as a minimum of 50 (very similar to how I was using the it with the Van's alternator).
In my case I had a little circuit board serving some other data conversion purposes already hooked to the EIS (converting the EIS serial out into a form acceptable to the GNS430 for fuel flow/remaing data), so it made a nice place to install the isolator.
Or just use a bulb in the panel.
