Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 12-29-2012, 03:46 PM
penguin penguin is offline
Default Wooden prop - how many threads into hub?
Hi,
I'm about to fit a wooden prop in place of a sensenich metal. I'm having to use a heavy & thick front spinner plate to keep the cg forward. How many threads should the prop bolts engage on the hub/spacer?
Pete
Old 12-29-2012, 04:05 PM
rv9aviator rv9aviator is offline
This won't answer your question directly but the rule of thumb as I know it is length of thread engagement needs to be at least as long as the diameter of the bolt. A 7/16 bolt would need to be screwed in at least 7/16 deep in order to gain max strength. All that means is the bolt will pull apart before it will strip the threads and pull loose.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
