Old 12-27-2012, 04:27 PM
jim plaster jim plaster is offline
Default leaking aero 20 locking gas caps
Has anyone come up with an overhaul kit for these fuel caps? I disassembled one and it has two internal smaller orings and the large flange oring. Mine are leaking at the key/lock area
Old 12-27-2012, 04:38 PM
scsmith scsmith is offline
Default Mine too
Mine are the standard non-locking caps.
Seems to me I saw a replacement O-ring kit somewhere -- maybe Vans or ACS.
I didn't need it at the time, but one of mine leaks now through the center shaft that expands the plug when you close it.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 12-27-2012, 05:07 PM
Default leaking fuel caps
Looks like they have a kit for the non-locking caps. Mine has the retrofit Newton 20 locking caps . Just email the manufacturer in the UK for help on parts.
Old 12-28-2012, 09:44 AM
penguin penguin is offline
Yeah, email the Newton in the UK, all spares are available.
http://www.newtonsprl.co.uk/
Pete
Old 12-29-2012, 07:37 AM
Default fuel cap kits
Emailed Newton and he's supposed to get back with me next week. Got a response from A/C Spruce last night....the kit is available via special order from Newton. If anyone else is interested the part number is ohk-z2 and cost $10.50... I tried using Google to view the contents of the kit but nothing shows up there....I guess it's all top secret stuff!
Old 12-29-2012, 07:51 AM
Most people in England are on Christmas break until 2nd Jan (no Thxgiving here).
Pete
Old 12-31-2012, 05:44 AM
Default fuel cap leaks
Got a response from Newton this morning basically telling me to contact a/c spruce again for help. They also refused to give me manufacturer part numbers on the kit contents....pretty much useless "**** on a boar hog" info.What ever happened to product support??
Old 12-31-2012, 06:04 AM
Len Len is offline
Default Gas Caps
I have the same leak but now in both caps ... I need the kit also !!
I sent a note to ACS and Wicks to see if either one will reply !!
Len
Greensboro, NC
Len Leggette
Greensboro, NC
Old 12-31-2012, 04:26 PM
Default leaking caps
len,where are yours leaking? Mine are/were from the key slots on both caps. Hate to say it BUT...I've fixed both caps until the kits get here...went to Harbor Freight and bought one of their o-ring kits ,disassembled the caps and re-oringed the lock assembly and the main seal on the cap. The third oring appeared fine so I fuel lubed it and reassembled the caps...No Leaks for now...I know its a temp thing but siphoning fuel all over the wing in flight was making a mess..I'm going to get up with the girl at a/c spruce and order several kits since theyre cheap....I'll get spares if you like...jim in winston-salem
Old 01-01-2013, 06:58 AM
krw5927 krw5927 is offline
What's an Aero 20 locking gas cap? Is it the one Vans sells as an option to the wing kits - the one with its own flange and NOT the retrofit?
Like this one?
http://www.vansairforce.com/communit...hlight=o-rings
Kurt W.
RV9A
FLYING!!!
