John
I have a 7A and an io360B1B, so went through this same struggle, although it was some time ago. No pics to share right now, but I can tell you to be very careful about the eyeball location for the mixture cable There is very little room for the flexible part of the cable on the engine side of the firewall, and with the additional limitations posed by the engine mount and the firewall stiffeners, its a challenge to make it work, but it can be done. A short piece of tubing to act as a spacer between the arm on the fuel servo and the bering on the end of the mixture cable may help you get the clearance you need from the engine mount. I also remember having to get pretty creative with hacking up the AFP-provided bracket. If you really get stuck, let me know and I will pull my cowl and get some pics of my installation
Good luck
Erich
