12-28-2012, 08:49 PM
And here's the last chapter to this entertaining troubleshooting event...
This morning, my engine guru managed to pull himself away from his wife's honey-do list for some man cave time. We snuck away to my hangar to get to the bottom of this mystery.
We began by pulling the injector from all four cylinders. Using brake cleaner and Q-tips, this is what we got
Based on the stuff found in the injectors, we backed up to the inlet filter in the fuel servo, where we found more cruddies. The crud found in the inlet filter had the look of fine-hair fiberglass mat.
Based on the CRUD found in the fuel servo, we backed up to the fuel filter located upstream of the electric fuel pump. We found larger chunks of debris. The debris was smearable black material. The amount found in the fuel filter was not very much. It may have blocked about 1% of the fuel filter. The dismaying part is that the fuel filter had been cleaned during my last annual about 20 engine hours ago!
Based on the black, smearable material found, we postulated that it may be ProSeal that may be breaking off in the tanks and migrating through the filters. If you remember from a previous post in this thread, I run MoGas most of the time. (non-alcohol Premium grade) So I drained both fuel tanks, and allowed them to dry out for awhile. Using a q-tip taped to a long stick, I swabbed several ProSeal locations inside the tanks to see if there was any softness or failure in the ProSeal. I didn't get any smearing of the ProSeal.
Next, I hooked up a fuel pump to the fuel tank sump, added five gallons of AvGas, and recirculated the fuel (through two in-line see-through filters) back to the tanks for about an hour. The filters did not seem to get any dirtier, but I did not cut them open to examine the media up close. Finally, I filled the tanks with AvGas and went up for about twenty minutes of pattern work. Everything ran fine at this point, and I'm almost done with this chapter.
My last action item will be to open up the fuel spider, remove the diaphram, and clean out the orifices in the spider to make sure that there's nothing left in the system.
Although I've been flying for 480 hours on MoGas, I think that I'm going to have to stick to AvGas. I don't know if I got a bad batch of fuel that caused all of this trouble, or if this was building up and just finally reached a peak. (I think it's the bad batch of fuel - based on cleaning all screens and filters just a few hobbs hours ago.)
Scott "Grumpy" Stewart
RV-7 N957RV (First Flight on Dec 18, 2009 )
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
12-28-2012, 09:24 PM
Scott, you're fuel filter is the problem, not the mogas. Its not fine enough to catch the crud that is making its way upstream.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
12-28-2012, 10:29 PM
Scott,
Would you mind posting what fuel filter you are currently using?
David
12-29-2012, 01:31 AM
Originally Posted by digidocs
Scott,
David
Van's Fuel Injection Installation Kit
I have the standard fuel injection system from Van's with the Airflow Performance fuel filter.
Arlington, WA
12-29-2012, 02:27 AM
Good job but.....
Hi Scott,
While all this stuff if bad I would not assume that it was the cause of your problem.......it may be, but for you loose a cylinder, the fuel feed to that cylinder would have to be temporarily cut off.
Compression, fuel and a spark are the three things you need, so a sticky valve could still be the thing that actually caused it.
I have often come across situations like this where you think you have found the culprit only for the problem to occur again, so take care for the next few flights.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
12-29-2012, 04:40 AM
The MoGas - do you transport it by some means to your airplane? If so I would look at these items first.
Doug Gray
RV-6 completed, flying since July 2010
12-29-2012, 05:23 AM
Originally Posted by DakotaHawk
The AFP filter is 125 micron so it's not an overly fine unit, I prefer to use a 74 micron unit.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
12-29-2012, 07:03 AM
Where to source?
Walt, where to you get that 74 micron filter and will it fit in the Airflow performance housing? Is the pressure drop much more to affect vapor formation? Thanks.
For reference:
Oil filters ~ 30 micron
Diesel prefilters ~ 15 micron
Diesel fuel filters ~ 5 micron
Bill
RV-7
Lord Kelvin:
12-29-2012, 07:20 AM
For reference:
I use a FlowEzy 3000 unit, you may want to check with Don at AFP for a replacement element source on his unit.
