Old 12-25-2012, 04:59 PM
Default Cold weather and flying
We had a discussion at the hangar about this and while we both had heard various no-go temperatures, neither of us knew exactly why. So I'll put it out there this way: What's the temperature, below which you will not fly?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Last article: "Gonna Finish This Sucker" (Kitplanes)
Waiting for the avionics kit (backordered: chip shortage)
Old 12-25-2012, 05:41 PM
scard's Avatar
scard scard is offline
Ours are almost entirely pilot limitations. We've gotten to the airplane and looked at each other on a beautiful clear day and said "what were we thinking", and gone back home. I know it is funny, but this is supposed to be fun.
Scott Card
CMW E-Lift
VAF Advertiser
Old 12-25-2012, 05:46 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
-459.67 F.
0.0 K if that is easier to remember.
Jeff Point
RV-6, RLU-1 built & flying
ATP, CFI, Tech Counselor, Flight Advisor & President- EAA Chapter 18
Milwaukee
Old 12-25-2012, 05:54 PM
tclaire tclaire is offline
0F to 5F once in the air with a good heater you don't know the difference, I have vetterman mufflers with heat muff, it amazing how much heat you get.
Tim
Old 12-25-2012, 05:58 PM
rzbill's Avatar
rzbill rzbill is offline
Ice sucks
Bill Pendergrass
ME/AE '82
Old 12-25-2012, 06:08 PM
Sparky's Avatar
Sparky Sparky is offline
Bob,
I agree with Scott that it is a personal limitation more than anything.
There is almost nothing better than flying in cold Minnesota on a clear day. Aircraft performance is amazing in the dense cold air and there is almost no turbulance. I really enjoy it.
However, when the temperature reaches about -10 to -15 degrees F, for me, the pain outweighs the gain.
So my personal limit for enjoyable flying is -15 degrees F.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
Old 12-25-2012, 09:03 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Try a J-3 on skis in subzero temps (out of Anoka County) ... but I was a lot younger then!
I really don't have any firm temp limits in terms of flying - so long as the airplane comes out of a warmed hangar if the temps are below freezing. Preflighting and getting ready to go in the cockpit when everything is frozen is just plain work!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-25-2012, 09:13 PM
Rupester Rupester is offline
For me, it's about +10F. I'm a wimp.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 12-25-2012, 11:16 PM
Ralph Inkster Ralph Inkster is offline
As I get older my cold weather limit is rising. Currently -10F is plenty cool enough- and that's coming from a Canadian.
Realistically, with a properly prepped aircraft -25F is doable, if not comfortable. But if you are up for winter flying (fantastic by the way) be sure to personally prep with winter survival gear aboard too.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 12-25-2012, 11:23 PM
mtnflyer mtnflyer is offline
Default Cold cold cold
Here in the mountains of Colorado it is common to fly at temps in the minus 5 to minus 10 if the sun is shining but then I installed two heat muffs, one on each bank. With the sun shining in the cockpit it stays quite nice, but heaven help you if you fly under a cloud. One interesting thing happens quite often is to have way below zero on the ground and temps as much as 30 drgrees warmer a couple of thousand feet in the air.....
