Old 12-25-2012, 02:09 PM
YellowJacket RV9 YellowJacket RV9 is offline
Default Protecting scuffed metal
As I finish up my empennage I have realized that I haven't done as well as I should have at protecting the rudder skins from minor scuffs. No deep scratches or anything and I am planning on painting eventually, but I am wondering if there is anything I can or should do to protect the surface from corrosion over the next few years while I build. I live in a salt air environment. I am using AKZO on the inside surface, would that be tough to paint over or could I consider priming the rudder skins for protection in the meantime? I am keeping the vinyl on where possible but I guess a few scuffs were bound to happen. I have since put carpet down on the workbench.
While I await advice I am going to make my VAF donation!
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 12-25-2012, 02:24 PM
ColoRv's Avatar
ColoRv ColoRv is offline
I would not worry about it. It's not going to see actual rain and even if it did, it's alclad. If a Cessna on the ramp doesn't corrode away to nothing after 30 years....I imagine yours will be ok. My rv4 wings and emp spent a couple of years in my garage in Orlando without any issue anyway.
Just my opinion, others may disagree.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 12-25-2012, 02:37 PM
Gary 40274 Gary 40274 is offline
Default Prep for painting
The first thing you do to prep for painting is get out the sandpaper and scuff up the surface. Just don't worry about the minor scratches, they are just prep for painting.
Gary
Old 12-25-2012, 04:51 PM
Thanks all for the reassurance. Now, to finish this stupid leading edge. Worse than the trailing edge!
Chris
Chris Johnson
Old 12-25-2012, 06:35 PM
bret's Avatar
bret bret is offline
Be sure to take all the blue film off, corrosion can start there.
Old 12-25-2012, 08:10 PM
Rupester Rupester is offline
Default leading edge ...
.... Is definitely harder than the trailing edge .... Unless you have the hands of a 10 yr old to hold that bucking bar.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
