12-23-2012, 08:31 PM
Originally Posted by newamiga
Guys I figure I will ask this thread since it appears to be related.. how cold is too cold to fly? I don't mean being comfortable in the cockpit but rather for the Rotax and the carbs. I ask this because a friend and CFI was flying a Rotax powered low wing two winters ago. She took off when it was about -5 ambient temp in Denver. The wind chill dropped it below that. She took off, went once around the pattern and did a low approach over the runway. A bit more than halfway down the runway the engine quit. She was able to get it onto the runway and stopped. The A&P suggested that the severe cold weather contributed to the carbs inability to properly operate. There was no other mechanical issue found.
Not trying to derail the discussion but I am curious how cold others are flying their RV-12's? Living here in CO, we get our share of colder days. I like the rest of you love to fly in the colder air in the winter in my Rotax powered Gobosh while trying to endure the temps to continue the build.
Carl
Per the Rotax manual....Max (120F Ambient) Min (-13F Oil Temp)...start or operate. I only know because our ambient can get near the 120 on those rare occasions.
Pete
12-24-2012, 07:23 AM
I've flown the -12 at -7f, but that is after preheating the engine and oil to 40F. I preheat below 30f. There is plenty of warm air from the radiator, oil cooler, exhaust system to keep inside the cowel area warm. Remember, the air intake is on the back of the engine so it is getting "warm" air.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
12-25-2012, 04:40 PM
Heater temp
Thanks. That helps a lot. I am just finishing the Service Bulletin and doing a condition inspection at the same time. We are including a number of mods at the same time. Moeller fuel gauge, heater baffle, oil cooler moved forward, AOA, vernier throttle, and baggage compartment bulkhead mod.
Richard
120002
12-25-2012, 06:17 PM
Richard
120002
Your going to love the vernier throttle - I did all of the mods you did as I built. I went EAB from the start, but the throttle is great & so smooth!
Enjoy it.
12-26-2012, 02:52 PM
CURRENT REPORT - -
Just got home from flying. Shoveled a foot of crusty snow away from the door. The airport does good, but can't get closer than a foot or two. Was ( -6C ) on the surface, and ( -10C ) at 3500'. Brought the CHT's up to 210 degrees with my Heater Damper Door. Was very confortable. TOTAL overcast, so only the heater was warming things. Could see for miles, but no sun !
John Bender
12-26-2012, 03:19 PM
Preheat is important for the 912 series. It is also quite easy to do. A pair of hot pads on the block and oil tank is cheap and easy, and will probably help get you to / beyond TBO. There are other systems that work better at preheating, but cost more.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
12-26-2012, 07:32 PM
I use the - -
Reiff pre-heat ( about $225 I think ), and it works great. I keep it plugged in all the time, and cover the nose with a packing blanket. If I turn on the display, the ENTIRE engine is 90 - 95 degrees. No warm up time required. Just taxi and go.
John Bender
12-26-2012, 07:41 PM
The Reiff rules! I recently started using the Pilot Portraits Cellphone switcher. I call the PP switcher a few hours before I fly and it all works great. Saves a lot of fuel on warm up.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Currently restoring a 1978 Citabria GCBC
12-26-2012, 07:48 PM
I use the Geiger Pre heater.
Works great, cheap, adds no weight.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
