12-21-2012, 10:13 PM
Preparing for FAA/DAR Inspection
I'm finishing up my RV10 and thinking towards the day I will be ready for my DAR inspection. I know they will want to look into inspection panels, but what needs to be removed for inspection? I'm wondering about the panels inside the fuselage that are attached with screws but don't obscure anything significant behind them - like the belly panels on other wise of the RV10 above the seat pan and under the door jam? Will they need to be removed? I'm curious as they are a pain to get in and can imagine scratching the paint easily. If so, I'm considering leaving them out until after the inspection. But it they wont need to be removed for the DAR, then I know I can leave those sorts of panels in.
CharlieWaffles - But you can call me " Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
12-21-2012, 11:13 PM
This varies a lot from DAR to DAR, or FSDO inspector. Ask him or her what they want.
12-22-2012, 12:02 AM
Senior Curmudgeon
Right answer.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
12-22-2012, 04:58 AM
Talk with the DAR. He should tell you exactly what condition he wants the airplane. Be organized, have all the Ts crossed and Is dotted. This shows him you pay attention to detail. You need pictures to prove to him and him alone that you built the aircraft. Ideally, this inspection should be like a check ride, a learning experience.
Kevin Phelps
Paid thru Dec 2020
RV-7A flying N782WP
Stuart, Fl
12-22-2012, 05:35 AM
Charlie..open up the "essentials"... Wing attach covers on the wings, top and bottom cowls, prop spinner, baggage area bulkhead, so he can look at the pushrods, etc. tail fairing so that he can inspect stabilizer and rudder attach bolts and possibly aileron bellcrank covers.
Good luck,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
12-22-2012, 06:52 AM
I agree with those who suggest contacting the inspector and finding out exactly what they want to see. Every inspector, whether a DAR or and FAA ASI, have slightly different approaches to how to conduct an airworthiness inspection, so knowing what your particular inspector is going to want or need will go a long way toward making your experince painless. A little bit of preparation goes a long way!
Cheers!
Joe
12-22-2012, 07:42 AM
All posts so far are accurate. Each inspector has slightly different requirements. Typically FAA inspectors are more interested in paperwork. Most DARs like to delve into things a little more.
As an example, I want the aircraft opened up as if you were doing an annual condition inspection. I want to see all control and fuel hook-ups. Out of 700 aircraft I have done 3 that I couldn't find a discrepancy.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
12-22-2012, 09:05 AM
Thanks "Mark" for asking the question;
And all you guys for the answers.
I'm also very close to the Airworthiness Inspection for my RV-8.
I guess we are reluctant to 'get inspected'. After all that work, someone comes along and tells us how we did it wrong or the hard way, or it needs more work...
And the fear that it won't pass and might need follow up inspection?
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Reason: sp
12-22-2012, 09:07 AM
I figured it varied with each inspector. Since I am a few months away still I haven't selected an inspector but given what Bruce said perhaps I should start looking at what available options are and begin planning for that.
RV-10
N928MT
Build Project Site
12-22-2012, 11:55 AM
Inspection
Had the FAA do my inspection this past summer. On that day, two FAA inspectors (and their manager)arrived with inspection mirrors, flashlights, with the intent to do a complete mechanical inspection. I was warned not to expect a sign off on the first visit. They initially had some 'design issues' with the Vans (per plans) rudder stops and manual trim tab wiggle. On the second visit, all was OK! Overall, they performed a very thorough inspection which I appreciated. Best of all, it was FREE.
Jim Diehl #71976
7A
Lock Haven, Pa.
