12-17-2012, 06:35 PM
AWI 4 into 1
Looking at the AWI 4 into 1 for my RV8 , what about cabin heat ?
12-18-2012, 06:45 AM
Should be plenty of room for a big muff on the #1 downtube....assuming you want a muff, a nest of scat hoses, and a big hole in the firewall, all just to get iffy heat.
I wired for hot vest power ports instead. Equal and independent heat front and rear. However, we're now into the third winter and we've never plugged one in. The Showplanes canopy seals better than the slider, so the solar heater has been plenty here in the South.
Dan Horton
RV-8 SS
Barrett IO-390
12-18-2012, 07:57 AM
+1 on electric only heat... and the lack of use.
I can't imagine a Florida airplane would need heat very often, if ever.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
12-18-2012, 06:55 PM
Heat
Thanks for the info , already own an electric jacket ( motorcycle and open cockpit biplane ) . Guess I saved some money not needing a heater valve .
Happy Holidays,
Tom
12-21-2012, 08:01 AM
Excellent cabin heat with this system
The Spot-welded studs on the AWI exhaust system transfer a lot more heat to the air than the Vettermen non-stud setup. I have had both on my plane and the AWI system will put a lot of heat into the cabin.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
12-21-2012, 08:28 AM
I have the AWI system and had them coated by Jet-Hot (ceramic coating). I am happy with the AWI system (although my JH chrome-look option discolored). As for heating (I live down the road from you in Cape Canaveral) I did not want my engine compartment cluttered with heat muffs etc. so I had automotive seat heaters fabricated into my Flightline Interior seats. I used them once for a few minutes then shut them down as they were to warm even on the low setting. You might consider that configuration unless you are going to head to the Mason-Dixon and parts North.
Don Stiver
RV8 "Little Pill" N6371S, Merritt Island, Fl.
BPE IO-390, Dual P-mag, MT 3-blade, AFP system
Steen Skybolt: Sold
12-21-2012, 09:48 AM
FWIW, I'm a little farther north than you (in SC) and also have power wired to each seat (separate switches) for electric clothing (vest, etc) which like others I have in my inventory from motorcycling (sounds like a trend, doesn't it?). Anyway, I've never turned them on (over two winters now), either.
Lee...
Lee Logan
Ridgeland, SC (3J1)
F1 Rocket #160 flying
12-22-2012, 09:17 AM
heat option
Just a thought....you might be able to set up a heater using your oil cooler as a heat source...or a second oil cooler inside the cabin with a selector valve. Good luck, Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
01-11-2013, 09:20 PM
AWI
Received the AWI system today , very nice , 321 stainless ,.049 wall , 1.75 diam tubes , aprox 12.5 lbs . They had a price increase from $1188 to $1495 .
Tom
