DWG 33 shows the actuator rod end getting the following hardware:
AN4-10A Bolt
3X AN960-416 Washers
AN365-428 Nut
So you should have bolt, weldment, washer, rod end, washer, weldment, washer, nut.
No cotter pin needed.
A better way to safety the rod end bearing is by drilling a small hole through the rod end. No relative motion between the parts, so the safety wire won't work harden and break. I also put some loctite on the threads.
