Old 12-15-2012, 11:14 AM
drmax drmax is offline
Default O-320 crankcase breather tube
My neighbor who has built a 6 and Rocket, commented on how I could make an improvement on my purchased 9A. I was concerned on the minor oil weeps in the engine compartment. He pointed out that as the breather tube is, it is pressurizing the case. If the tube were extended down and pointed rearward, this would create a negative pressue and most likely illiminate the weeps. It would be a quick fix. Your thoughts?
Old 12-15-2012, 01:43 PM
The pressure is miniscule. It won't cause oil leaks.
But without it, you will get a huge amount of oil on the belly very quickly if you don't properly secure your oil dipstick.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-15-2012, 02:05 PM
Hi Kyle, so are you saying to leave it alone? Sounds to me without the positive pressure, more oil would come outta the tube? I'll forget about it.
Thx
Old 12-15-2012, 03:49 PM
Thx
Yes. I recommend leaving it alone.
I had a bad experience with it beveled the way your friend suggested.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-16-2012, 08:47 AM
10-4
Thank you
